Sounds like a 2 stroke? Possibly on 3 cylinders? 92 CBR600 F2
Old 10-12-2013, 04:24 PM
Sparky92CBR600's Avatar
Default Sounds like a 2 stroke? Possibly on 3 cylinders? 92 CBR600 F2
Hey folks,
I've had this CBR for about a year now, and although it never really wanted to start, and never ran great, it ran. One day a few minutes after I touched redline it started acting funny. I emphasize a few minutes after because it may have been a coincidence. It died, then I restarted it after several attempts and this is when it started sounding like a 2 stroke. I had to rev it to keep it running and lost most of my power. I limped it home and checked the valve shims. Most of them were below spec, which means the buckets are closer to the cam than they need to be - something which makes no sense to me.
Regardless, I have done everything else. I have pulled the carbs off a half dozen times, cleaned everything out like the pilot and main jets, pilot screws, etc.
I was wondering if anyone had symptoms like this and could confirm it was the shims? And anyone else that can explain why the buckets are now closer to the cams than they should be? Clearance is supposed to be .16mm on the intake side and I'm getting .03mm and .05mm on #1 and 3 respectively.
edit: I have read the Valve Adjustment thread on here, it was helpful for measuring but I want to confirm this is the case before I spend $80 on shims.
Also, I had a horrific gas leak when I put everything together after a couple months of sitting around. I had a few cups of gas pouring out, and after ensuring the gas line was tight, and float bowls were sealed, I just got it hot, and that seemed to fix it. I searched around and no one had a clear answer so if someone stumbles on this, check your seals and then get it hot.
Old 10-13-2013, 12:50 PM
sunday bump
Old 10-13-2013, 03:37 PM
gtcole's Avatar
Welcome Crew
id you by chance check your plugs too? Im just asking cause you didnt mention it
Old 10-13-2013, 04:20 PM
Good point, I forgot to mention I pulled the plugs and used a spark tester and all were sparking.
edit: Also thanks goes out to f3cbrAnt I was able to get the bike timed, it just took me a while. :P
Old 09-21-2018, 05:17 PM
Phil314's Avatar
Originally Posted by Drake Gillespie
I've been doing some research it is possible that it may be the throttle position sensor(tps) picking up a multimeter today.
Mainly because the bike landed right on the sensor. Also its a fuel injected not carb. should have mentioned that in first post. Wish luck
1-Adam-12, 1-Adam-12, WTF???
Old 09-22-2018, 04:19 PM
tentacleslap's Avatar
Yeah I think he might have meant to post this on his thread "05 cbr help diagnose running like a 4 stroke"
Probably just a typo when he used the search
Drake - this is an old thread for a different model. I'll go ahead and move this post to where it should be just as soon as I figure out how to use my new moderator tools...
detroitcbr
08-10-2019 10:32 AM
Nick Smith
08-05-2014 01:48 PM
knifemaker87
03-23-2011 10:58 AM
P_Glasovatz
04-02-2010 10:02 PM
jakemc
05-05-2008 02:12 PM
Quick Reply: Sounds like a 2 stroke? Possibly on 3 cylinders? 92 CBR600 F2
