And she's playing hard to get...
So I got new parts for the exhaust system, more exactly the gaskets, bolts and M8-to-M7-pins that goes into the engine housing. I got two of the M8-to-M7-out by tightening the bolts near the engines so that they somehow jacked into the pins and could be use as something to grip when loosening them. However, four of the pins seem more or less rusted stuck. I have used WD40, I have tapped them with a hammer, I have tried everything but welding since I don't know how to weld. Any ideas? I don't know how the engineers were thinking when they constructed those pins. Couldn't they at least have given them a nutlike appearance in the center of the pin to be used for tightening/loosening?
It could be, as the diaphragm in the petcock could be damaged - then what can happen, depending on how bad the diaphragm valve assembly is messed up (if it is), is the vacuum from cylinder 1 can suck fuel into the cylinder through that vacuum line, throwing things off in yet another way.
Screw two nuts back to back onto the threads, tighten against each other and use the inner one to turn the stud out. Try to hit the wrench with a hammer rather than turning hard to nudge the stuck thread loose or you risk snapping the stud in the threads which would get you to another realm of getting p!ssed! Trust me that'll surely get tools flying!
The simplest way to remove/install a stud, is to use two nuts on the stud, tightened against each other, so that when you turn the inside nut counter-clockwise, when removing a stud, it locks against the outside nut, and loosens the stud from the part it's threaded into.
It's ideal, when the two nuts line up with the sides all matching, so you can use your wrench/socket on both nuts at the same time, kind of like in this picture:
![](http://farm8.staticflickr.com/7229/13295154155_10474376e7_o_d.jpg)
Obviously, penetrating oil can help, and heating the surface the stud is screwed into can ease removal as well, but of course, the worst case scenario is the stud can snap off, leaving you with a much bigger job, so proceed with caution!
