-   F2 Tech (https://cbrforum.com/forum/f2-tech-93/)
-   -   rebuilding the engine (https://cbrforum.com/forum/f2-tech-93/rebuilding-engine-110445/)
knifemaker87 May 11, 2010 10:39 AM
Hey
i just got a 600 f2 last weekend as a project and have some questions. The PO snapped off one of the alternator cover bolts and so the bike started leaking oil, so i drained the oil. The bike hasnt been run in a while and so he also filled it up with coolant and now, the bike is leaking coolant out of that same hole. i am assuming that there is a blown gasket causing this problem. My first plan is to rebuild the engine and replace seal gaskets etc.
I assume this has been done before, and was wondering what the best resources are for me to follow/read? A tutorial would be great, but i was planning on just putting everything back like i found it.
any help would be appreciated.
thanks
~Chris
ljung May 11, 2010 11:05 AM
I would recommend the Haynes 2070 it's great.
( Honda CBR600F2 & F3 Fours '91 to '98 )
"Every Haynes manual is based on a complete teardown and then a step-by-step rebuild. Everything is covered – from a complete engine rebuild to changing an oil filter."
cardshark99va May 11, 2010 02:23 PM
what part of the 7 cities u from? im in chesapeake or at least i will be next month when i finish up college. i can probably email u a repair manual if u wanna give me ur email
knifemaker87 May 11, 2010 02:27 PM
I have one in the mail now. great resource. i didnt realize they made them for motorcycles! sweet!
hey, i am up between Newport News and Williamsburg. if you wouldnt mind sending the manual that would be great. Email is Knifemaker87@gmail.com
thanks!
~Chris
nitrodude May 11, 2010 04:53 PM
If/when you do end up rebuilding the engine, I would love to see pics of your work and details on what you did to it.
knifemaker87 May 11, 2010 07:48 PM
i will make sure to take plenty of pictures
thanks!
~Chris
cardshark99va May 12, 2010 02:20 PM
heres some sites u can download it from for free
http://hondatech.info/downloads/Moto/CBR/
http://www.cbrextreme.com/downloads/...manual-14.html
