Ok, I think my fork springs are bad.
#22
yep
Yes you hes right you can add a spacer and you will like this since your a cheap ace
Go to ace, get some type of tubing, i used copper, cut a sleeve and add that to your fork internals.
What will it do? right? Well theoretically your spring rate is linear with a 1mm of travel for every 1 lb added downward, by adding the spacer you can change the dynamic and it will act like a stiffer spring because it will already be partially compressed with the spacer on it.
get it ?
get it ?
#25
get it ?
get it ?
#27
