need to remove my rotor/flywheel need to find tool. HELP!!!!!
You should be able to order it from just about anywhere. I had local dealer order mine from Parts Unlimited. It looks like a small 4 way lugwrench and has fit every bike I've worked on since. A bolt with right thread will work too if it's long enough (it's an unusual thread). Screw it in til it stops and hit it with impact, she will come right off.
a large puller will do the trick. I tried everything. My friend came over with a large puller and had it off in 2 seconds. I screamed that was bull$*&#, and told him to leave, he got it off though. Also, the only thing you have to make sure is that the drive for the puller is small enough to fit inside the hole in the middle.
