-   F2 Tech (https://cbrforum.com/forum/f2-tech-93/)
-   -   Need help bad... (https://cbrforum.com/forum/f2-tech-93/need-help-bad-137875/)
titus sublett May 9, 2012 07:28 PM
Need help bad...
Ok I'm trying to sell me bike so I can get a new one, but I have to get this one running before I sell it.
I was working on the rectifier and the wires touched. I got a new wire harness so it wasn't on correctly. So the wires were exposed and they touched.
I then go a new fuse for the starter relay and it ran fine. When I turned it of to see if it would start again nothing happens. I can push start it. But when I hit the starter nothing happens. The only light on my speedometer that works is the high beem and it turns off when I hit the starter switch.
Can someone please help me. I'm so ready to get back on the road.
titus sublett May 11, 2012 08:08 AM
Starter not working
My rectifier wires were exposed cause I got a new one. I was trying to fix it and the wires touched.
Now when I hit the starter nothing happens. I checked all the fuses and got a new relay. Still nothing. I could push start it but not anymore
MadHattr059 May 11, 2012 05:59 PM
Check the main 30amp fuse. Not sure where it is on the F2.
On the F3, it's in the same housing as the starter relay.
Un-do the connector and you can open the housing to access it.
It may be similar for the F2.
Ern
JankCibberf2 May 11, 2012 09:31 PM
Check your battery too. My bike did the same **** with a bad battery. Also, if your jumping the bike with a bad battery it'll destroy your electrical system an replace the r/r again
titus sublett May 11, 2012 09:48 PM
well i would push start the bike and then take the cable off the battery and it would cut off. so does that mean it is my battery
wagzhp May 11, 2012 11:26 PM
Sounds like a nearly dead (or maybe just uncharged) battery, and likely a failure in the charging system. (Most likely a failed stator.)
titus sublett May 12, 2012 05:17 AM
Well could it be the rectifier since that is where the wires touched
JankCibberf2 May 12, 2012 08:08 AM
could be everything if you keep running it good sir. Pull the rectifier and see if the plastic is all melted like
titus sublett May 12, 2012 09:49 PM
Well I have tried touching the wires again and nothing happens. Its like there is no power getting to the red wire.
titus sublett May 14, 2012 10:26 PM
I know its not the battery. I had it tested and its fine. I try jumping it but when I take the cable off battery it cuts off. Please I'm so ready to get back on the road
