Need help bad...
Old May 9, 2012 | 07:28 PM
titus sublett's Avatar
Default Need help bad...
Ok I'm trying to sell me bike so I can get a new one, but I have to get this one running before I sell it.
I was working on the rectifier and the wires touched. I got a new wire harness so it wasn't on correctly. So the wires were exposed and they touched.
I then go a new fuse for the starter relay and it ran fine. When I turned it of to see if it would start again nothing happens. I can push start it. But when I hit the starter nothing happens. The only light on my speedometer that works is the high beem and it turns off when I hit the starter switch.
Can someone please help me. I'm so ready to get back on the road.
Old May 11, 2012 | 08:08 AM
Default Starter not working
My rectifier wires were exposed cause I got a new one. I was trying to fix it and the wires touched.
Now when I hit the starter nothing happens. I checked all the fuses and got a new relay. Still nothing. I could push start it but not anymore
Old May 11, 2012 | 05:59 PM
MadHattr059's Avatar
Check the main 30amp fuse. Not sure where it is on the F2.
On the F3, it's in the same housing as the starter relay.
Un-do the connector and you can open the housing to access it.
It may be similar for the F2.
Ern
Old May 11, 2012 | 09:31 PM
JankCibberf2's Avatar
Check your battery too. My bike did the same **** with a bad battery. Also, if your jumping the bike with a bad battery it'll destroy your electrical system an replace the r/r again
Old May 11, 2012 | 09:48 PM
well i would push start the bike and then take the cable off the battery and it would cut off. so does that mean it is my battery
Old May 11, 2012 | 11:26 PM
wagzhp's Avatar
Sounds like a nearly dead (or maybe just uncharged) battery, and likely a failure in the charging system. (Most likely a failed stator.)
Old May 12, 2012 | 05:17 AM
Well could it be the rectifier since that is where the wires touched
Old May 12, 2012 | 08:08 AM
could be everything if you keep running it good sir. Pull the rectifier and see if the plastic is all melted like
Old May 12, 2012 | 09:49 PM
Well I have tried touching the wires again and nothing happens. Its like there is no power getting to the red wire.
Old May 14, 2012 | 10:26 PM
I know its not the battery. I had it tested and its fine. I try jumping it but when I take the cable off battery it cuts off. Please I'm so ready to get back on the road
