-   F2 Tech (https://cbrforum.com/forum/f2-tech-93/)
-   -   Larger Front rotors again (https://cbrforum.com/forum/f2-tech-93/larger-front-rotors-again-163409/)
ernest62 Mar 30, 2023 01:29 PM
All the threads on larger F2 front rotors are old so I thought I would aske again. Has anyone had any luck locating larger rotors like the EBC's recently?
dannoxyz Mar 30, 2023 02:15 PM
Larger ST1100 296mm rotors will fit on F2 wheel.
Problem is adjusting mounting position of calipers to line up with larger rotor. No one makes an adapter that I could find. Easy enough to make your own.
So I used F3 forks, F2 wheel and ST1100 rotors.
https://drive.google.com/uc?export=d...7VUMkEAbEJTNUl
