Installed aftermarket gauge cluster/digital cockpit. Video included
After my gauge cluster went out I started to look around for a decent used one or easy aftermarket option. The ones I found were really expensive, tho. And they had a ton of miles on the odometer. At this point I decided to buy a cheap universal aftermarket digital cockpit. I made a little video and thought I'd share it here and answer any questions people might have about it. check it out.
You didn't by chance do pictured among the way did you? This would make a mean write up.
I didn't unfortunately. But I can at least run thru the steps. I'll post exactly what I did later today
Help with wiring
Originally Posted by Cenquizca
(Post 1244824)
Danmoto cockpit on cbr 600 f2 - YouTube |
Which cluster did you get ?
Have link to product or its manual? For every electrical part, you need 2-wires: power and ground Ground is common to all circuits, so it can share wire. Here's what's needed for winkers: green = ground, connect all circuit's grounds here org/wht = left winker +power blu/wht = right winker +power Most likely 2 wires on clocks just need org/wht and blu/wht connected. |
Originally Posted by dannoxyz
(Post 1354165)
(Post 1354165)
