Help.... Wont start ,just backfire
I'm mean the fireball is awesome but I would rather hear her purr.
Here is what I'm working with 1991 CBR600 F2 Parts I've replaced R/R Suzuki gsrx version wired up correctly. New Stator New ngk Plugs gapped correctly .035 New to the bike main wiring harness ,right hand control and ignition switch. New starter solenoid Cleaned carbs and fixed leak at the inlet T's New battery Drained tank and New fuel 91 oct Here's my issue When cranking the motor over, it turns over but every 10 seconds BOOM backfire. I've made sure there is enough fuel going to the carbs, made sure the plug wires are in the correct order and coil leads are the right ones feeding the right wires. Put the battery on the trickle charger to make sure its good. Had it tested at a battery shop just in case also. Checked spark with each plug out against the block. Not sure how much spark I should see but each plug had some. I've toggled the kill switch and cleaned the terminals on that and the ign switch. What else can I check or what might it be?? Thanks in advance for any ideas or advice. |
1 Attachment(s)
She Runs :icon_dance-twist:
Apparently what i thought was the right leads feeding each coil was backwards. Here is a diagram of how the coils and wires should be laid out. Attachment 32992 Now on to the next issues :icon_frown: Leaky Radiator,bad CCT and on and on, but im getting there. |
Glad you got it figured out. It's a long process fixing things. But well worth it. Good luck
It was just nice and a relief to actually hear the motor run since i bought this bike knowing it didn't run.
If it weren't for this forum , i would be completely lost. So if i have any useful info ill always pass it on,Hence the drawing of the coil routing. |
Originally Posted by 91-CBR600-F2
(Post 1233508)
Apparently what i thought was the right leads feeding each coil was backwards. Here is a diagram of how the coils and wires should be laid out. https://i743.photobucket.com/albums/...afd9e39a39.jpg Now on to the next issues :icon_frown: Leaky Radiator,bad CCT and on and on, but im getting there. |
I will check if I have some photos of this in a few hours.
Originally Posted by Chris Sherman
(Post 1301115)
im having this same problem where exactly is the coil I have a 93 cbr600 picture if possible. Thank you in advanced
http://www.motoguerreros.com/wp-cont...51078631_n.jpg
Originally Posted by Migge
(Post 1301342)
hey guys, im sorry to just jump on this thread with a diffrenet issue but im new here and im also pretty new with motorcycles even tho i have basic knowledge....i need help!!....I restored a 89 cbr 600F, new everything, the only thing i havent touched is the engine pretty much. I jetted it and if runs wtihout any issues even tho it never felt fast. last night my friend purchased a 2010 ninja 250r and i wanted to race it thinking i was going to blow passed him, but sadly I couldnt, it actually pulls on me a little, that cant be right. can you guys point me in the right direction, i am very discouraged...thank you
also where is the air mixture screw on this carbs. I dont wanna drill a random hole on the side of my carbs.....thank you again guys
Please help😏😏😏
Please advice would be greatly appreciative
i have a Honda cbr 600 f2 1994 wont start just back fire have replaced few bits ie coils spark plugs Rectifier cdi pick up battery cut off switch ignition barrel fuel filter fuel pump fuses relays cleaned carbs so far I have spark fuel and compression it turns over for a few seconds then boooom back fire little fire from exhaust if I pop little carb cleaner down ports it stutters put fuel in it backfires was running great, pulls great I parked it up as broke foot so couldn’t ride now foots better wanted to ride the beast again and the above started so I though would replace bits but pulling hair out now any ideas would be much appreciated thanks mark |
| All times are GMT -5. The time now is 07:24 AM. |
