Help, rear brake light does not work.
In result i can not ride. While pulling in front brake or pushing down on rear brake the rear light does not get brighter. I have been reading around a bit here and discovered the patterns of the wires and re traced. I have checked fuses and bulbs and even moved the ground wire to assure it was grounded out. All turn signals work too. I read about a rear pedal switch and how that can be an issue? now would that tie into the front brake as well bc as i mentioned neither of them trigger the light to become brighter. Please any suggestions will be greatly appreciated!!!
I would get a voltage tester and start from the rear...from the brake light socket, find the trigger wire...see if there is juice when appling brake (F/R)...then work your way back to the rear brake & front.
If there is juice immediately at the socket, maybe your 2 terminal bulb??
It's 90% connection...
+1, dual filament bulbs. The brake side can burn out with tail lights still working. Cheap to replace anyway. If thats not it, check the fuse. Then make sure that your charging system isnt putting out too much and blowing bulbs or fuses. Its probably not, but good to check anyway.
+1 to estates pointing out that your bulbs have 2 filaments...
both switches work independently, but could have issues. make sure the rear switch it being pulled enough to trigger the lights and that the front switch is working. they could have gone out at different times and you didnt notice. but check bulbs and fuse first.
74demon is always willing to help...so remember to vote for him on March ROTM....Lol....
Back to the topic... That's why it's important to test the socket with a voltage tester...any $2 12V tester from harbor freight will do...on the rear socket (parking light and brake light) there is one ground wire (usually black), one wire that has constant juice once you turn on your key, then there is one wire (trigger) only has juice when you apply brake...now if you test the trigger wire and it does work when applying brake, then you know for sure it's the bulb...If you look at the bulb up close, there is 2 filament...one high one low...guessing the high one is brake light....
Now if you test the trigger wire and no juice?
Then work you way back, it's connection/fuse/relay...something is cutting off the brake light trigger...
Lastly, you've not mention the history?? Was brake light working fine when you purchase bike...did you do any mods may have cause this? When going inside the tail section, look for anything not norm? Sometimes previous owner may have done something....
Adding these types of info will help, if you are still unable to resolve brake light issue by the above suggestions made.
