Help / Advice needed for a broken bolt
Hi all, fairly new to the forum and messed up royally this morning.
My buddy was giving me a hand putting on my new tires. We were all done and just going around with the torque wrench and I'm not sure if it slipped or didn't work but I I've broken a front axle pinch bolt (tension bolt). Any direction on what to do with this? I suspect it needs to come out so what is the best way to do this? Will I have to take the forks off? I thought I would go ahead and change my tires now and save myself the trouble in the spring but my luck has been s^%t lately and I toss this one up to no good deed (or intention) goes unpunished. Any feedback really appreciated. Picture Link: https://lh5.googleusercontent.com/-t...n%2520Bolt.jpg |
Is any of it sticking out?
A pic or two would help so we can see what you're dealing with. You may be able to get it to back out, if you can get a little grip on it. |
Originally Posted by 74demon
(Post 1256567)
A pic or two would help so we can see what you're dealing with. there is a link at the bottom of the post. I can see pictures on here cause I'm new and don't have the proper rights so I don't know if it's working or not. Unfortunately, it snapped of in the middle. May be able to get at it from the other side, J |
I saw that, but I was looking more for a close up and to see if its sticking out the back side.
Are there threads on the broken piece? |
Here are more pictures. I got a little sick to my stomach after I did this and forgot to upload the other pictures I took.
https://lh6.googleusercontent.com/-6...%2520Bolt2.jpg https://lh3.googleusercontent.com/-C...%2520Bolt3.jpg |
Don't worry. Its not that big of a deal.
Is any sticking out the back side? The good news is the shank is out. That bolt will screw out either way. It shouldn't be tight at all. Try using a small screwdriver and catching a broken ridge and back it out. If there is some sticking out, use a hacksaw blade to cut a slot in it for a screwdriver. |
(Post 1256578)
Is any sticking out the back side? The good news is the shank is out. That bolt will screw out either way. It shouldn't be tight at all. Try using a small screwdriver and catching a broken ridge and back it out. If there is some sticking out, use a hacksaw blade to cut a slot in it for a screwdriver. The questions I should have asked is whether its okay to ride like this. I can't see why not but just in case it's better that I ask this now. Thanks, J |
Success!
(Post 1256578)
Is any sticking out the back side? The good news is the shank is out. That bolt will screw out either way. It shouldn't be tight at all. Try using a small screwdriver and catching a broken ridge and back it out. If there is some sticking out, use a hacksaw blade to cut a slot in it for a screwdriver. Good things too as I had put the speedo back on incorrectly so then I had to remove, fix the speedo and remount the wheel. Thanks a MILLION! J |
Be careful when retorqueing bolts. I installed new front brake pads and when retorqueing the caliper bolts, I was doing it slow and easy and noticed that the bolt was getting easier to torque instead of harder. So I stopped immediately and took it out. The bolt was getting ready to break. It was skinny in the middle where it was stretching. So I replaced all four caliper bolts and saved 3 of the old ones for an emergency.
