Head bolt torque specs
Old Feb 21, 2012 | 11:52 AM
JankCibberf2's Avatar
Default Head bolt torque specs
Well i've torn my spare motor apart to learn how to work on motors but now its coming time to tare apart my good motor. Does anyone know if the torque specs of the f2 are the same torque specs as the f1 hurricane? I have the clymer manual for the f1 from my buddy and its been a great help so far, i just don't want to over torque everything
Old Feb 21, 2012 | 02:58 PM
underground-mpyre's Avatar
Go get a 'Honda' Service Manual, not clymers or haynes but a 'Honda' Service manual. Easily find them on Ebay. When in doubt, torque to the specs of an F2, not F1. Aluminum is a fragile metal to overtighten anything, I wouldn't even guess at this if I were you. You cannot correct aluminum!
Old Feb 21, 2012 | 05:52 PM
MadHattr059's Avatar
+1 underground,. If you want all of that hard work to come out right, get the factory manual. It is a cheap investment into the health of your baby.
Ern
Old Feb 22, 2012 | 11:20 AM
Optimus_Prime's Avatar
I agree with the guys above. I just put the cylinder head and cams back on my F2 engine and I had a printed out copy of the service manual with me the whole time so I can check and double check the torque specs. It's pretty easy to find the F2 manual online and download a copy.
Old Feb 22, 2012 | 05:23 PM
37ft.LBS. for the heads to the block. Make sure you only slowly and carefully cross-bolt tighten the heads down a little at a time for a good seal.
Old Feb 22, 2012 | 07:39 PM
^^thx my good man, do you know what it says for the crankcase bolts as well?
Old Feb 23, 2012 | 06:44 AM
This is where I recommend getting the 'Honda' service manual. It is depending which bolt you go after, some are 9lbs, 17lbs, and 24lbs. I would love to help you out, but I do not won't to give you bad advice and you have a 125lb paperweight.
Old Feb 23, 2012 | 04:47 PM
When 3 out of three, make a suggestion, trust us on this one. I know/understand the
drive to "Get 'er done", but it really is worth it's weight. To have the answers/procedures
right in front of me, really helps the "flow", when I'm wrenching on the scooter.
If you're constantly start/stopping, you'll increase the odds of making a mistake.
Check the how-to for the online-manual thread, at the very least. Although,
personally, I dig having the book open in front of me. I've only got a 17" svga
monitor in the garage, so it makes it harder to really see the details of the PDF form.
Plus, you can't throw the monitor over the seat, to reference. lol
Ern
Old Feb 23, 2012 | 09:46 PM
lol it's 9lbs for the crank case 6mm and 17lbs for the 10 8mm bolts and 24lbs for the 1 10mm bolt. at least for the crank case.. then my torque wrench went to **** so i didn't touch the head bolts... i'm literally looking at this motor like omfg i can't believe im doing this but now i haz to wait but oh well its cold and snowing outside no rush
sublimelx
Jul 24, 2011 03:18 PM
CbrRod
Jul 10, 2011 04:05 PM
Cr250r67
Feb 22, 2010 11:11 PM
mwr2452
Nov 25, 2008 09:32 AM
HawaiianBB
Feb 29, 2008 12:26 AM
