A few questions about my new F2
I just bought an F2 so I don't know too much about the bike. I took off the 2 side fairings today and I saw that the Coolant was bone dry. Not even a drop in the damn thing. I then checked the brake fluid and it was a little below the bottom line. I also checked the Transmission fluid (I think) and it seemed okay but maybe a little low.
So I have a few questions...
Are there any other fluid levels I should be checking? I am sure there is a way to check the Engine Oil but I can't find it anywhere. (No owners manual).
What kind of Coolant do I put in the bike? Will car Coolant work?
Anything else I should know guys?
Thanks!
Thanks!
Transmission fluid is actually your OIL. These bikes have a wet clutch, so the clutch is in the oil.
I would do the following to any new bike in which the prior maintenance isn't guaranteed:
Replace all the coolant
Replace the oil and oil filter
Clean the carbs
Replace the air filter
Replace the spark plugs
Do a valve inspection/adjust
Auto coolant will work, although engine ice is reltiavely affordable and should treat your bike better.
Clean the carbs
Okay great thanks for the help. Carbs were actually jetted over the winter so that is fine.
What are all the fluids that are in the bike?
Brake, Coolant, oil...Anything else?
edit: Are all of these fluids that I will be replacing able to be serviced by only taking off the right fairing?
What type of engine oil do you guys use?
How do I access the Air filter?
Sorry for all the questions haha
Thanks
Thanks
I use castrol syntec part synthetic. It treats my fine.
There are no other fluids, besides blinker juice
Remove all the plastics and do a general inspection of everything anyways. It requires little to no work.
Air filter requires removing the has tank. The air box is beneath it, and inside of that is your air filter. Removing all this gets you on your way to the spark plugs, so you might as well do them while you're there. At this point it'll have had a full tune up.
The carbs were "jetted" over the winter... as in rejetted or you just cleaned the current jets?
Thanks
Thanks
http://www.cbrextreme.com/downloads/...manual-14.html
Use a 50/50 mix of distilled water (Never tap water!!!) and antifreeze. Make it easy on yourself and just buy the pre-mixed stuff (Green, not Dex-cool), verify the bottle says safe for aluminum blocks. Bike will take about 3.5 quarts IIRC, so a 1 gal bottle will be all you need, and you won't use all of it. Fill the radiator up to just below the port where the hose from the reserve/overflow tank plugs in. Run the bike for a minute or 2 with the cap off, kill the motor and refill the radiator - do this for a few cycles til the radiator quits taking fluid. Use towels - this process will result in some fluid sloshing out of the radiator - make sure it doesn't slosh onto your brakes/rotors.
Once you have the radiator filled properly, then add coolant to the overflow tank up to the full line.
Take the bike for a drive, then park it till everything fully cools off - check level in the overflow tank, top off as needed.
