F2 Gearing vs Speed chart
Old Apr 13, 2012 | 07:38 PM
YankeeBravo's Avatar
Default F2 Gearing vs Speed chart
Using an html chart by Janis Braslins, I have modified it to include the F2 in the preset data. To use this schart, go here: Motorcycle gear/rpm/speed calculator
You will see a "preset" drop down list, click it and find the F2 at the bottom. Select it, then hit Load Preset button. Chart will display various top speed (theoretical - calculated) at certain RPMs. You can change the final gearing easily by just entering a new number and hit TAB. The chart will recalculate the speeds.
Again, the real work is by Janis Braslins, I just added a little data... If you have better gearing data, let me know, but this is based on what I could find on the internet about the F2 gearing...
Old Apr 13, 2012 | 08:03 PM
RoadiJeff's Avatar
Senior Member & Lord of The Man Cave
I use the Gearing Commander website. Just load your bike's stock data from the drop-down menu and experiment away with different combinations.
bluej511
Aug 15, 2009 06:13 PM
helacus
Jun 3, 2009 04:59 PM
GsusFrk
May 29, 2007 12:30 AM
PitbullF4i
Aug 13, 2006 11:56 AM
sputnik
Nov 14, 2005 07:57 AM
