engine running weird after rebuild
So i blew my headgasket a couple weeks ago along with a piston and a cylinder wall (never order parts from ronayers or w/e the **** it is, idiots sent me the wrong headgasket, **** never matched up) anyways. After replacing it changing out the pistons and cylinder heads and putting this crap all back together. my motor was having some issues starting, and once i finally did the bike ran like crap. Super under powered and almost like it was mis firing. Any ideas? Im thinking the plugs are shot after being submerged in 80 billion degree coolant
who knows, bike had like little to no compression tho, sooo dropped the motor again and need to order new rings. Tried re using old ones and looks like it backfired. Oh wellzzzzz any site recommendations for ordering? not going with ronayers because this is basically their fault to begin with1
I have not had to re-build my F2 motor (yet), but if and when I do, I will probably only use Wiseco products:
Motorcycle Forged Pistons & Performance Parts - Wiseco Piston Inc.
Man, I have said many times, the F4i pistons are exactly spec at the lowest fractional cost. F4i compression is 12:1 and wiseco are 13:1, but cbrzone has the 637 .018 big bore head gasket to make that up. You will spend less money on are outdated relic like ours.
