electrical help
Old May 18, 2012 | 09:35 AM
titus sublett's Avatar
Default electrical help
I have no power on my bike. I checked the fuses already and they are good. I changed the starter relay as well. I can jump the bike but it won't stay started unless the jumper cables are on.
Old May 18, 2012 | 09:41 AM
74demon's Avatar
did you check the main fuse (30a) thats not in the fuse box?
Old May 18, 2012 | 09:57 AM
Yes the one in the starter relay right
Old May 18, 2012 | 11:05 AM
74demon's Avatar
i think there is another that feeds the fuse box. do your fuses have power?
Old May 18, 2012 | 11:28 AM
Nope not unless it is started. It seems as if the battery isn't getting any charge
Old May 18, 2012 | 11:37 AM
74demon's Avatar
is the battery low and the cables clean and tight?
Old May 18, 2012 | 11:51 AM
Yep battery was checked its good. And cables are tight
Old May 18, 2012 | 11:57 AM
74demon's Avatar
hmmmm, sounds like a dead battery. but if its good and charged up then that cant be it. will it stay running long enough to take a voltage reading on the charging system?
Old May 18, 2012 | 12:34 PM
estate4life's Avatar
February 2012 ROTM
Hold on, clarify first before members can help.
1. You mean when you insert you key into ignition, turn it, you're getting nothing??? No light what so ever? All black out like a dead battery. This is correct?
1. Then you use a car to jump cable. Once connected, bike starts, cranks, and idles find. But when you disconnect jump cable, the bike shuts off. All blackout...no power. Right?
3. Did you check ground wire(-)
4. Did you check all fuses including the main.
Old May 18, 2012 | 08:58 PM
How do you check the ground wire
