Denso plugs, oil behind valves, etc.
I got my F2 project bike running two months ago and have ridden it for over 1K miles now. All I did was a thorough carb cleaning and sync. While doing the work, I inspected the existing NGK plugs which are a little black but are otherwise okay so I reused them after slight cleaning.
I got my new Denso (IUH27) plugs yesterday and decided to install them. It was a good time to have a look at the old NGK plugs, anyway. I removed the carbs to do this and looking into the intake ports, I saw oil behind the valves on cylinders #3 and #4. There is a good drop or two collected behind the valves which happened to be fully closed. The liquid looked greenish initially but I wiped it off and it is, indeed, oil. Do I have a valve guide problem? The bike fell on its left side while parked about 2 weeks ago. I've ridden it without any issues. The bike starts every single try. I am not detecting any loss of oil.
When I removed the plugs, there is some oil on the threads of each one. The electrodes had no additional wear from the last time they were checked and the insulator is a slight tan. Except for the oily threads, they looked very good. I installed the new Denso plugs and put the bike together after some cleaning. I can't believe how much better the bike runs now. Throttle response is much better and the engine revs more readily than before. I used Denso iridiums on my S2K also and thought I felt a difference but the improvement on my F2 is much more apparent.
I will take a look at the plugs and check on the oil behind the valves after a few rides but if anyone has any experience with this, I'd appreciate your insight.
Thanks!
Thanks!
Thanks!
Thanks!
