Changing the grips? HELP NEEDED ASAP!
I bought some grips and the guide said they fit "1993 Honda CBR 600F2". I was worried because they are slip-on. The left side was tough to get off, but finally got it. I'm worried about the throttle side, as it seems to be possibly tied into the throttle casing? I don't want to go trying to pull it off if I could damage the throttle cable/casing. But if the right side is also a slip-on it'll be no problem. Below are the photos of everything.
http://oi41.tinypic.com/256grkp.jpg http://oi41.tinypic.com/2lazcpl.jpg http://oi44.tinypic.com/110dfrm.jpg |
I would take a utility knife and cut the old one off. I would carefully slit it all the way, left to right, trying not to scar the throttle tube, then peal it off like a banana.
Originally Posted by coalminer frank
(Post 1248906)
The old ones that say CBR on them are thick aluminum, can't cut them off. Took a vice grip and hammer to pull the left off.
I've got a feeling those gold aluminium grips that are on your bike already have the throttle tube built into the grip. You'll probably have to open up the switch casing to disconnect the throttle cables to be able to remove the grip. Then you'll have to get a new stock throttle tube to have something to put your new grip onto.
No experience with those aluminium grips but that's my best guess. |
Looking at the center pic with the grip off you can see two small diameter circles and a drag mark in a somewhat sine wave pattern. Your grip appears to be attached using a small diameter set screw. Loosen the set screw and your grip should come off fairly easy. My guess is the throttle grip has it located on the underside.
This is a video of installing billet grips on a ducati... but I would bet money the process is pretty much the same on your CBR... Check it out... Might be useful in helping you remove yours...
Hey RedBull... I'm curious how this turned out...
Did you get your throttle grip off? If so, what was the secret? Did you get your new grips installed? If so, where are the pictures??? Inquiring minds want to know ;) |
Hey, I actually kept the old ones on it. The left grip was pretty beat up since I had to use a hammer to get it off, so I grinded it and wrapped both of them in electrical tape with a few yellow stripes. I also took the spike tips off and painted them black. They look much better and match the bike. The bronze color didn't go at all...
Here's the outcome. http://oi39.tinypic.com/6e2jw7.jpg http://oi39.tinypic.com/20v0xa9.jpg |
Instead of electrical tape which will get sticky with heat and time, try using some tennis racket grip tape or bicycle handle bar tape. Good selection of colors, thin or thick, gel or not. I've gotten about 9K miles on my current wrap and they're just starting to show some wear. The grip is good in wet or dry.
