Carburetor Cleaning & Tuning 101
Old Aug 24, 2009 | 07:57 AM
  #31
Dissevered's Avatar
Originally Posted by antatious
Oddly enough after all of this, I discovered a slow leak in my rear on the air stem. Those arent very expensive to replace are they?
Thanks
Never had to replace one for a bike,but I know car stems are cheap so hopefully bike stems are too.
Old Aug 24, 2009 | 06:17 PM
  #32
young_gun's Avatar
Got them done.. Took longer than expected! Just started it up after cleaning out the filter! Thanks for all the help, i would normally wait for help from my older brother or dad but with your help i was able to do it myself! Just hope nothings screwed up...
Old Aug 28, 2009 | 04:33 PM
  #33
96@cbr's Avatar
bump...
Old Sep 1, 2009 | 02:35 PM
  #34
Nzimwale's Avatar
Default Great walkthrough
I've just been looking at doing this, going to start tomorrow. A great help - thanks!
Old Sep 4, 2009 | 05:49 PM
  #35
CBRfenatic93's Avatar
I was wondering if i should add those fuel system cleaners to my tank like right before an oil change or something? Would adding the carb cleaning ones affect our bikes? I know its a noob question but im just trying to be safe and not damage anything.
Old Sep 5, 2009 | 01:04 AM
  #36
lqdcat's Avatar
in one of the first pictures...what does that breather hose attach back to? I just noticed mine was disconnected. Is this why my bike won't start?
Old Sep 5, 2009 | 08:14 PM
  #37
sugar22's Avatar
hi
can u tell me the right float level for this kind of carb. i guess it's too high; now the float level it's upper then the Float bowl. it's near the Keihin log where is write JAPAN. bay the way how can adjust the float level; looks like it's impossible, no screw, and the Float Tang it's plastic.
thx
Old Sep 6, 2009 | 09:34 AM
  #38
Dissevered's Avatar
Originally Posted by sugar22
hi
thx
You guessed it, there is no way to adjust the floats. Just make sure the valve part is nice and clean. Knock the pin out to pull out the needle valve and clean the needle and seat.
Old Sep 8, 2009 | 12:12 PM
  #39
Nateclimb's Avatar
Most likely a dumb question but how often should you do this??
Old Sep 8, 2009 | 01:19 PM
  #40
johnnyx's Avatar
Whenever you need it. It's not maintenance, it's a repair, so it falls under "don't fix it if it ain't broke." Doing it before it's necessary is just a waste of a severe amount of time. Some have gone 25k+ without ever needing it. My bike sat for 3 years with no stabilizer, so I needed to do it even though it only had 9500 miles on it.
