Carb Jetting Database
Please keep other info out of this thread. Only answer the questions. Copy and paste to keep format uniform.
Year: Location: Elevation: Temperature Range: Air Filter: Jet Kit: Pilot Jet: Main Jet: Needle Clip Position: Fuel Screw Setting: Exhaust Type: Exhaust Modified: |
RE: Carb Jetting Database
Year: 1993
Location: BC, Canada Elevation: Sea level Temperature Range: 10-30C Air Filter: OEM stylePaper Jet Kit:DynoJet Stage 1 Pilot Jet: 38 Main Jet: 124 Needle Clip Position: 2nd from top Fuel Screw Setting: 1 1/2 Exhaust Type: Hindle slip-on Exhaust Modified: No |
Year: 1992 f2
Elevation: sea level Temperature Range: 0-28c Air Filter: pipercross Jet Kit: dynojet stage 1 Pilot Jet: 40 Main Jet: 130 Needle Clip Position: top groove Fuel Screw Setting: 2.5 turns out Exhaust Type: delkevic headers with viper race can Exhaust Modified: no |
Year: 1993 F2
Elevation: Sea Level Temperature Range: 40°F ~ 85°F Air Filter: K&N Jet Kit: Factory Pro Pilot Jet: ?? Stock ?? Main Jet: Had 130s when I got it, wound up with 134s, then cut the muffler, currently running 140s, got 142.5s coming Needle Clip Position: Center Fuel Screw Setting:About 1.25 turns out Exhaust Type: Factory with D&D Slip-On Exhaust Modified:D&D Slip-Onshortened by approximately 8" |
Year: 1992
Location: Tacoma, Washington Elevation: Sealevel Temperature Range: 20-90+ degrees Air Filter: UniFilter for a 1000 Jet Kit: Keihun factory jets Pilot Jet: 38 Main Jet: 132 Needle Clip Position: 2nd from top Fuel Screw Setting: 3/4 turn from 0 Exhaust Type: D&D full header and shorty can Exhaust Modified: Um... I think so. Those jet sizes are estimated. I installed them a while ago and can't find the receipt or the bags. |
Year: 1993 F2
Location: Kissimmee Fl. Elevation: Sea Level Temperature Range: currently 60° to about mid 70s Air Filter: K&N Jet Kit: Factory Pro (but now using Mikuni Jets) Pilot Jet: 38S Main Jet: 142.5 , perfect for current conditions Needle Clip Position: Center clip Fuel Screw Setting: About 1.25 turns out Exhaust Type: D&D slip on with factory header Exhaust Modified: D&D Cut Down to 10" in length |
Year: 1994
Location: northeast florida Elevation: sea level Temperature Range: 30~110f Air Filter: paper Jet Kit: DJ stage1/factory pro ti/honda oem Pilot Jet: #40 keihin (oem for a 95 f3) Main Jet: 124 Needle Clip Position: top Fuel Screw Setting: 1 3/4 Exhaust Type: scorpion steel baffled slipExhaust Modified: n/a |
Year: '94
Location: Bulgaria Elevation: +300/400m Temperature Range: +20 to +40'C Air Filter: K&N Jet Kit: K&N stage 7 Pilot Jet: stock Main Jet: 135(stock) Needle Clip Position: in the middle Fuel Screw Setting: 2 turns out Exhaust Type: Short Exhaust Modified: Ceramic Thermo Wrap |
Year: 1992 CBR 600 F2
Location: Portland Or Elevation: Sea level, and have ridden it up to 3000 feet thus far without issue Temperature Range: 40-100 degrees Air Filter: K+N Filter Jet Kit: Dynojet Stage I kit Pilot Jet: Stock Main Jet: 126 jet included with kit Needle Clip Position: 2nd from top (per instructions) Fuel Screw Setting: 1 + 7/8 turns out (experiencing some popping on deceleration below 6k rpm) Exhaust Type: Micron Exhaust Modified: Nope. Full write up of noticed difference and experience is below: https://cbrforum.com/forum/showthrea...678#post895678 |
Westchester, NY
Year: 1994 CBR 600 F2
Location: Pound Ridge, NY Elevation: ? Temperature Range: 30-100 degrees Air Filter: Aftermarket W/Airbox mod Jet Kit: Factory Pro Config #30 Pilot Jet: Stock Main Jet: 150 jet included with kit (Might step up to the 155) recommended with kit. Needle Clip Position: 2nd up from bottom (one below middle) Fuel Screw Setting: 2.75 turns out Exhaust Type: Vance and Hines header custom midpipe with 2.5" cat converter as muffler Exhaust Modified: Yep:icon_bike: |
| All times are GMT -5. The time now is 06:23 AM. |
