Can't make the front wheel sleeve move enough to tap out bearing
Exactly what the title says, I got the rear ones out no prob but can't do the front. Whats the hidden secret here I'm missing? Thanks in advance
you mean you need to deflect it some to get on the other side's inner lip? - I would say a prybar, or a drift/punch and a hammer. The sleve shouldn't be that tight to begin with- that's an indication that the bearings were pressed in too far.
Since you're replacing the bearings, i wouldn't be afraid to pull out the BFH and a screwdriver or a drift. Can't hurt anything. |
Yea you were right, the bearings were pressed in too far. I managed to get a thick flathead on the edge of the inner part of the bearing to pound it just enough so that the wheel sleeve came loose. Got it done :icon_toast:
| All times are GMT -5. The time now is 01:16 AM. |
