cam degreeing on a F2
Old Feb 28, 2013 | 09:04 AM
squale147's Avatar
July 2013 ROTM
Default cam degreeing on a F2
just wondering has anyone took the time to do it and was it worth the time? and what lobe centers did you end up going with? and if you did a before and after dyno run and what was change in power? thanks for any info..
Old Apr 9, 2013 | 12:48 AM
gpfan1's Avatar
It might be worth an hp or two. Bonneville guys would do it for sustained top end, drag racers too. They used to make adjustable cam gears to play with years ago. You might research the difference in cams and see if a 94 or 95 would work. They had more power, but also used ram air and different carbs.
Old Apr 9, 2013 | 05:15 AM
squale147's Avatar
July 2013 ROTM
i have a set of ape adjustable gears and im going to research a few grinds..ape and megacycle still have a few grinds for the F2
