burning plugs way too fast
You keep posting and you keep leaving me with the impression you don't know what you're talking about. Espescially since you don't provide solutions. The pilots could also be off just as much as the mains, it's stupid easy to back those screws out halfway to west africa.
Anyways, post a picture of your plugs. Also, when riding, do you get popping on decel? Any funny noises or habits on accel? What's the exhaust system, what's the air filter, and has it been jetted?
Give us that information, and we can give you a direction in which to proceed.
the plugs are wet and black as night. the bike has only ran once for about 5mins with those plugs. i can't tell you about any noise or back fire because i've never ridin it. i need to get it running before i can ride it. sorry to be a pain. this bike had sat for 3 years before i got to it. when i got this bike the first things before trying to start it were. new gas, gas line, plugs, uni air filter, oil, oil filter, ect... do you think i need new rings? or have leaky valves? another thought was to get a jet kit or get new carbs.
I "stored" my f2 for several years. I had to replace floats, float valves, and petcock before I could get my bike to run properly. If it has just "sat" for three years you need to clean out your carbs for sure. The floats are plastic and bend of their own weight without gas to support them. The rubber tips on the valves get dented from the valve seat and don't seal totally. The petcock diaphragm gave up the ghost too. Sitting around is rough on any motorized vehicle, much less a high performance engine.
Check your oil too, as it is highly likely you are flooding out. The gas will go past the rings and thin out your oil. You'll smell it.
Stored=cleaned, drained, and covered.
Sat=stuff in tank, oil sitting, coolant breaking down. Clean, clean some more.
deucedeuce37
12-10-2006 05:07 AM
