EBC Brake Brakets
For some reason I cannot find the EBC relocation brake brackets that allow for fitment of the 310mm rotors.
Anybody know where I could get them be awesome. |
I purchased my brackets directly from EBC - the number for EBC USA is 818-362-5534.
The part number is BRK 15S. |
Thanks for the info JNS.
I spent the past two weeks looking around the web and could not seem to find them, I assumed that they had stopped producing the product. I called them this morning and this is true sadly, they discontinued this part some time ago. So it looks like a no go upgrading to 310mm rotors, someone maybe have a rough idea how much it would cost to have a machine shop custom make a set? I will probably just upgrade my stock rotors, I don't want to go to the F3 wheels and brakes and lose my F2 tach. |
Well, if you didn't have the part number before, I would do a Google search using "EBC BRK15S", just to see if you can find anything.
For what it's worth, you won't lose your tach when converting to an F3 front end, but I'm thinking you meant speedo! :D |
Nope, still can't find them. So if you know where I can get them by chance let me know. Otherwise it is discontinued and can't find them anywhere online.
With no speedo the tach is useless for a road bike because it won't pass inspection, and I'm not trying to make a track bike. |
Well, the good news is, if you're not working toward a track-ready bike, then there's no need at all to drop $450 on that rotor setup - the stock F2 brakes are somewhat underated, and I assure you that with new fluid, properly bled, an upgrade to stainless steel lines, and good pads, you'll have more stopping power than you'll probably ever need.
Now, if you DO have money to burn, then you could go ahead and upgrade to an F3 front end, and then install an aftermarket gauge set, that uses a sensor and magnets on the front wheel to get the speed reading. I haven't decided on which model yet, but I am going to be picking up one of these Koso sets before the start of next race season, maybe sooner, if I'm lucky! The RX-1N: http://farm4.staticflickr.com/3759/9...cfd2656fb9.jpg The RX-2: http://farm4.staticflickr.com/3691/9...960130d44e.jpg Or the RX-2N: http://farm3.staticflickr.com/2809/9...19c1aa8fee.jpg Good luck with whatever you decide to do. |
Should I just upgrade the current rotors on my bike then?
I already have an entire stainless line set, got it when there was a group buy on the forum a few years ago. My bike has been sitting in my parents basement for two years, sad I know. Started stripping chrome parts of and selling them, not a fan of chrome and way to much upkeep. The first owner had the bike stretched 8 inches and loads of chrome all over it and lowered 3 inches I believe, maybe more. Ill have to check that Been spending the last 3 years just buying parts, and have so many its time to finally start doing something. Looking to replace my entire brake system pretty much, rebuild both master cylinders and all caliper all new lines, just need pads in rotors. JNS in your opinion is the F3 setup worth the $$$? I know its much better design in general. Those tachs are really nice, but I prefer the F2 tach with the age of the bike. Plus hides everything behind it, to me more pleasing to the eye. |
I found an older post of yours JNS pretty much answering my question...
So if I have F3 forks already, I can get the entire calipers and lines and master from an F3. I have 41mm woodcraft clip-ons, I'm assuming the controls are the same on the F2 and F3? Including length of cables. So I just need a F3 front wheel and rotors? And then a corresponding tach that you posted in a previous post? |
Originally Posted by Brian1993F-2
(Post 1242305)
(Post 1242305)
(Post 1242306)
(Post 1242306)
(Post 1242306)
As far as the speedo issue, there is another option to consider - do a forum search regarding the F4i gauge conversion on the F2, where some folks used a front sprocket cover from a different model (not sure which), that has a speed sensor, in conjunction with a "Speedo Healer", to get the signal to the F4i gauge set. |
