-   Detailing (https://cbrforum.com/forum/detailing-36/)
-   -   removing decals (https://cbrforum.com/forum/detailing-36/removing-decals-64308/)
Cubllsu8338 Apr 2, 2008 12:00 PM
removing decals
i bought a complete set of fairings from motosfanclub on ebay and i believe he clear coated over the stickers. i really want to remove them and was just wondering will it leave a big outline where the sticker was and how notiuceable is it? Is there any way to get rid of that outline after the stickers have been removed? thanks in advance
cman9toes Apr 2, 2008 08:46 PM
RE: removing decals
Razor blade and a steady hand
Cubllsu8338 Apr 3, 2008 09:30 AM
RE: removing decals
i figured a hair dryer and a razor blade would work. im just wondering if you will still be able to see where they were seeings how there is clear coat over the stickers
D2VW14_20 Apr 3, 2008 08:56 PM
RE: removing decals
A hair dryer and a product called "Label and Sticker Remover" from advanced auto works the best.
Cubllsu8338 Apr 4, 2008 12:56 AM
RE: removing decals
but will there be an outline from the sticker because it was clear coated over?
D2VW14_20 Apr 4, 2008 07:37 AM
RE: removing decals
There is only clea coat on the take, and enough elbow grease will take care of it.
Cubllsu8338 Apr 4, 2008 11:46 AM
RE: removing decals
i bought a whole new set of plastic fairings for my bike so its not OEM honda. are you saying though that there wont be an outline from the clear coat?
cman9toes Apr 4, 2008 03:58 PM
RE: removing decals
If the clear coat is over the decals, you need to use a razor blade to cut the clear coat in order to remove the decal. It will be very hard to just peel the sticker off. If a outline is left, take the razor blade and shave it down. Something like goof off may take care of it, but I would be care ful with it.
Rpeterso1982 Apr 9, 2008 01:12 PM
RE: removing decals
You can do it but then the clear will peel or chip off. I did this to my bike as well and had to end up sanding and repainting otherwise your clear will chip off.
