-   Detailing (https://cbrforum.com/forum/detailing-36/)
-   -   Grease removal from wheels... (https://cbrforum.com/forum/detailing-36/grease-removal-wheels-143777/)
Incompatible Aug 1, 2013 01:57 PM
Originally Posted by 74demon (Post 1207709)
Dish soap and water. Gets grease off pots and pans as well!
I use it at work too. Better than that fancy hand soap with grit in it.
"softens hands while you do clutches"
Dawn Dish Detergent works great, I have used it for years to clean my tools and to remove grease from painted surfaces. Note: it will remove some brands of car wax.
I also found this on their website:
DAWN SAVES WILDLIFE! Dawn dish soap is used by Wildlife Rescue organizations to clean up animals effected by oil spills. According to the International Bird Rescue Research Center, Dawn effectively removes grease but does not cause harm to the skin of the birds and the solution is gentle enough to not harm the sensitive areas around animals’ eyes and feathers.. It’s also biodegradable and contains no phosphates.
Bryce Swartzwelder Sep 15, 2013 03:31 AM
Simple green works on some, but for wax based lubes and the white aftermath after the simple green is washed and dried i hit it with brake cleaner then air or prepsall and a rag.
CJardine Sep 15, 2013 03:52 AM
Been using used dryer sheets after yumi recommended it and it works so well.
allenpa5 Jul 13, 2015 09:58 AM
Dryer sheets? Really?
MrCanuck Aug 17, 2016 11:40 AM
this is perfect love this site, going to steal some dryer sheets from the wife when I get home, my rim is nasty
coalminer frank Aug 17, 2016 04:06 PM
Pledge furniture polish works. I use the cheap Dollar Store version. Takes grease off of hands and fairing also. Just spray in on a rag or paper towel and with away. It part of my arsenal of fluids I take to the track. Brake fluid, brake cleaner, oil, carb cleaner, WD, axle grease, water, glass cleaner, and furniture polish.
MrCanuck Aug 22, 2016 05:00 PM
Thanks for the tips guys went with the bounce sheets for the dryer, wow that was super easy to get off
