Detailing Discuss detailing your ride within.
Engine Paint
Old Sep 22, 2006 | 10:35 PM
Dave K's Avatar
Default Engine Paint
Is there a source for that brownish/gray engine paint used on the clutch and stator cover of my F4? Hate to buy new covers just to cover up a little wear.
Old Sep 23, 2006 | 02:49 AM
dragonium25's Avatar
Default RE: Engine Paint
If you're gonna touch it up, you might as well paint the whole thing whatever colour you want.
Old Sep 23, 2006 | 11:43 AM
Dave K's Avatar
Well, you are right. I would do that, but the color I want is the original color. Does anyone know where to get that.
Old Sep 24, 2006 | 02:35 AM
zerochickenstrips's Avatar
The original color is powdercoated, not paint. I'm sure there is a paint color that is close enough to it that it would match pretty well, but I'm almost positive they powdercoat them from the factory.
Old Sep 24, 2006 | 11:03 AM
Dave K's Avatar
Ok, thanks for the reply.
Old Sep 26, 2006 | 06:07 AM
Pugetpower's Avatar
I had the same problem with my 02 F4i. Scratches on the gold/brown/slightly green stator cover. Try Color-Rite.com. I took off the lower cowling taped up around the stator area and just sprayed it a Gloss Black. It blends in with exist color on the cowling. Except for us enthusiasts, you would think it was stock.
Old Feb 10, 2007 | 04:48 AM
1morebike.com's Avatar
if you are going to try to rattle can it, i've got a bit of advice.
first off, scuff up the powdercoat on it as good as you can. Use a decently abrasive sand paper to steel wool. Then, spray a self-etching primer over it before you paint. You can get it in a rattle can, and it helps promote a 'decent' bond.
good luck
Old Feb 12, 2007 | 12:30 AM
D2VW14_20's Avatar
Someone on here had the paint code for it and brand. I dont remember who but try a search and it may come up
Old Feb 26, 2007 | 02:40 PM
morehpforme's Avatar
Just do this:
yotatech
May 6, 2009 06:46 AM
yotatech
May 5, 2009 09:54 PM
yotatech
May 4, 2009 05:36 PM
sweetdeal
Jan 22, 2008 08:42 AM
Manowar Vin
Dec 31, 2007 12:56 PM
