'89 Stator Needed
I bought one from the US a month ago on e-Bay - cost with postage $100, so they do come up now and again.
falkon_powersports on eBay.com
You'll have to keep a daily lookout as they don't stay up very long. Try E-Bay UK too, and maybe Germany but their parts are silly prices.
Try japbikedismantlers in NZ - owner's name is Darrell - helpful guy.
Good luck.
http://www.japmcdismantlers.co.nz/
Are you sure it's the stator , not the reg/rec ?
Good luck.
Good luck.
Good luck.
I ran the tests on the R/R and alternator described in the Haynes manual as well as a Honda workshop manual which I have a copy of. The R/R checked out OK (although it may be fried now), but, measuring the (A/C) output on the three yellow wires from the alternator, I got about 50V (I forget the exact figures) on two of them and about 5 V on the other. When I took the stator out, I measured the resistance on the three yellows and got 0 ohms on wire 1 to 2, and on 1 to 3, but about 50 ohms on 2 to 3 (make sense?) So, I think this means the stator has had it.
So, I'll start the long prowl, but thanks in particular for the NZ contact: I am in Auckland as we speak...
Cheers
The stator is a Hitachi and the model number is: LD125-52. If that's the same as yours, let me know and I'll give you a call.
I have attached a photo as well.
Cheers
Always a pleasure - if you were closer, I'd lend you my spare stator, Boet
As for Pinetown, not much changes - stinking hot this time of year, as I'm sure you remember.
Best of luck - if the readings you put up are correct, the stator is definitely fried. DON'T throw the old one out - sometimes guys put the stator in incorrectly and break the lugs off, which renders it useless - ask one of our members in Estonia.HI Kaspar !! You should use a rubber hammer on the centre so it goes in straight, or............
Despite what everyone will tell you, you CAN replace the electrics in a stator...................
Cheers
Good tip, thanks.
Anyway, the good news is that it sounds like Aussie Johnno might be able to help me.
Cheers
And putting this thread to bed a couple of years later: I replaced the stator with a used one from Aussie Johnno (thanks AJ) but wasn't able to ride the bike straight away because I had started on a project in New Zealand and have been there pretty much full-time since then. However, now back in Sydney I've finally got the old girl back on the road: roadworthy, registration all done, new tyres front and rear, and she's running fine and the charging is 100%.
Thanks again for the help, guys, way back then.
