WONT START
so my buddies 929 wont start. when you turn on the key everything comes on except thefuel pump will not prime. the bike turns over but nothing else. we hotwired thefuel pump and it came on , started priming, then the bike would start and run for a few seconds with the fuel that was in the system. we checked everything electrical, tested all wires for continuity and power, all good. checked the B A S and it was good. we did alot more than this but you get the idea.. any suggestions?
[sm=headbang.gif] |
RE: WONT START
There has to be a relay or fuseable link going into the pump try to runn those wires. Did you try to jump bike off recently sometimes that will fry fuses. the connections need to be clean it could be something simple that gets overlooked. Sorry i couldn't be more help
RE: WONT START
ORIGINAL: CBR 600 F2 There has to be a relay or fuseable link going into the pump try to runn those wires. Did you try to jump bike off recently sometimes that will fry fuses. the connections need to be clean it could be something simple that gets overlooked. Sorry i couldn't be more help |
RE: WONT START
RE: WONT START
RE: WONT START
you said it only ran for a a few seconds with the fuel in the line, how did the bike run before this problem.. if it's not primping it's the relay... if it's not starting/running it's the fuel pump... maybe replace both
http://cgi.ebay.com/ebaymotors/HONDA...QQcmdZViewItem |
RE: WONT START
ORIGINAL: bobjoezx you said it only ran for a a few seconds with the fuel in the line, how did the bike run before this problem.. if it's not primping it's the relay... if it's not starting/running it's the fuel pump... maybe replace both http://cgi.ebay.com/ebaymotors/HONDA...QQcmdZViewItem thanks |
