Will 1000rr wheels fit my 954rr??
yes the wheels will fit but like pimpin said why
been awhile so i guess ill put up some new pics here these are pvm raceing from an o4 all i had to do was add 2mm of spacer between the caliper and the 04 1k spacer( a 1 1/8 inch washer was 2mm thick) i used the 954 axle though the 1k was too long. rotors also worked on the rear however on the front they will work but you will lose about 1/2 inch of brake contact (i think the 954 rotors are the same bolt pattern not sure)
