What Brackets do i need?
i need brackets to hold my front fairings, currently it is only held on to the side fairings with a couples of screws... The front head lights are not attached to any brackets it is screwed onto the front flairing. there is only a self-fabricated bracket that holds onto the instrument cluster.
DO i need this one? http://cgi.ebay.com/ebaymotors/HONDA...spagenameZWDVW Or this one? http://cgi.ebay.com/ebaymotors/HONDA...spagenameZWDVW they both says Upper Stay bracket.... but looks totally different. If i can have pictures of the brackets on the front end of the bike, then maybe i can tell which brackets i am missing.. Help please! |
RE: What Brackets do i need?
The 1st bracket will hold ur headlight into your front fairing, and it will also hold ur instrument cluster in place. That bracket mounts to the very front part of the frame between the upper and lower triple tree....The 2nd bracket will be the one that holds ur windscreen and front fairing in place........But BOTH brackets together is what holds the whole front fairing in place....Because those 2 headlight screws will hold the headlight into the fairing...So keep that in mind.........=-)
like he said.. basically need both for perfect fit the first one is for the gauges and part of the fairing and also the tip over sensor.. and the other one is for the uppper part of the fairing and the mirrors
