Turns don't flash...Help!
Old Sep 15, 2008 | 07:16 PM
prhockey21's Avatar
Default Turns don't flash...Help!
Ok. Just changed all my plastics and my front turn signals. The old and the new were both 2 wire. Now neither my front or back turns flash. They just stay lit all the time. They flicker for a second when I push the turn signal button but thats all. Do I need some sort of relay or something? Why would these be any different?
Old Sep 15, 2008 | 10:21 PM
letsride's Avatar
Default RE: Turns don't flash...Help!
I would check your wiring,maybe you installed incorrect.If they are OK then check the fuse.
Old Sep 16, 2008 | 07:16 AM
prhockey21's Avatar
Wiring looks good. Fuse looks good.
Edit: Just did a little more searching...Looks like they are just blinking too fast to see and I will need to wire in resistors to slow them down since I now have led's front and back.
Old Sep 16, 2008 | 06:26 PM
Hcstreetriding's Avatar
ORIGINAL: prhockey21
yup, resistors will fix it up. you should only need to wire it in the front or in the back and it will slow down the whole loop, or at least it worked for me. good luck.
Old Sep 16, 2008 | 06:45 PM
prhockey21's Avatar
ORIGINAL: Hcstreetriding
Awsome. Didn't get a chance to yet. Do you happen to know what size??
Old Sep 16, 2008 | 07:39 PM
BROOKLYN's Avatar
I read that electronic relay is the way to go...It seems as though some of the inline resistors get really hot.
77vetteguy
May 5, 2010 01:36 PM
drunkinmist
May 14, 2009 04:28 PM
chestnut1011
Sep 16, 2008 07:59 PM
andrewsi
May 12, 2008 09:43 PM
voodoochyl
Jul 27, 2007 08:15 AM
