Shifting Question
Old May 29, 2013 | 06:01 PM
Fordhamjc's Avatar
Default Shifting Question
So when shifting from first to second ... is it rough for anyone else? Does it make a difference say shifting at 4-5k rpms compared to 6-7?
Old May 29, 2013 | 08:08 PM
Conrice's Avatar
it's going to be the hardest shift you have because you'e bypassing neutral. so it should be a pretty long shift, but it shouldn't be "rough".
Old May 29, 2013 | 08:21 PM
Fordhamjc's Avatar
It's hard to explain. Its definitely louder. Like a louder click.
Old May 29, 2013 | 09:29 PM
backdoc's Avatar
929's and 954's are known for clunky shifting especially from 1st to 2nd. One of the best mod's for these bikes is to install a Factory Pro Evo shift kit. I just installed the shift kit a few months ago in my bike and now wish I had done it when I first got my 954 nearly 4 years ago. It makes shifting faster and smoother than the stock setup.
Old May 29, 2013 | 09:43 PM
Fordhamjc's Avatar
How much do those run and how difficult is the install?
Old Oct 6, 2016 | 07:25 AM
davebelcher's Avatar
I too had a few problems with this and was also told about the factory pro kit, Expensive to say the least with the star. What i did was inspect the whole gear shift assembly i.e everything. took the shift drum out- fine. took the shift rods out-fine. I then inspected the shift arm and there was a slight bend in it. I decided to replace the shift arm and spring and well.....perfect shifting for £15. Well worth a look into.
Drumsergeant
Aug 17, 2014 09:38 AM
josheboy
Sep 5, 2013 07:44 PM
Wisconsin
Apr 30, 2012 05:54 PM
ceazur
Mar 30, 2010 12:25 PM
racermike1967
Dec 1, 2006 01:32 AM
