replacing kill switch
i dumped my bike and i'm fixing it now and i'm replacing the kill/start switch assembly....but i need to disconnect the throttle cable....how can i do this with out taking the tank, air filter, air cleaner housing out....there has to be an easier way
RE: replacing kill switch
take clip on.. off and unscrew cables and then replace the unit
1 Attachment(s)
take of right clip on use screwdriver should take 10 minutes make sure you make a note of where the cable is running so when you put it back you dont make it tighter.. i did that after replacing an engine and i must say im to lazy to fix it
Attachment 84144 |
| All times are GMT -5. The time now is 09:58 AM. |
