rear brake job question
Got another question about this 2002 954. I was replacing the rear pads and noticed the soft rubber washer came out and the only place I can figure out where it fits is between the caliper and the bike at the top bolt with the smooth surface. And the other issue I'm having, at this time, is that when I put the caliper back on the bike and after bleeding the brakes, it seems that the caliper moves a little when applying the brake. I don't see this being normal so if anyone knows where that rubber washer goes and have any thoughts on the rear caliper movement it would be greatly appreciative.
