Problem with Rumble Concept Integrated taillight
I just installed a Rumble Concept Integrated taillight on my 02 952. It's plug and play with one wire hook up on each side for blinkers.
The problem I'm having is when the bike is idling or low rpms the rear blinker stays on and the front one blinks crazy, but when I'm riding and turn the signal on at high rpms it blinks fine. Front and back. Protons in front and stock rear blinkers worked fine before Rumble install What could be causing this? Battery going bad? Anyone come across this problem? I have Proton LEDs in the front btw. Thanks in advance for any help. |
You will need to put a resistor between the positive and negative wires on both your blinkers to simulate a bulb being there. LEDs do not draw enough current to make the flasher work properly. You can pick these up most parts houses. You can YouTube how to hook it up.
Originally Posted by ride red
(Post 1270562)
I would skip the resistors and change/add a relay.
Originally Posted by mika_u
(Post 1270677)
