Oil leak
Hi there guys, I rode my bike to work as I always do (daily commuter) and when I got out I noticed a small amount of oil under my bike, so I took off the left fairing and it seems that it's leaking from where the water pump meets the case...
I already bought the o-ring that goes in there, so the question is...has anyone gone through this procedure?? Any pointers??? |
Never mind guys, I have just replaced it, like 10 mins ago, if someone is to face this in the future I'll give some pointers...
It is not necessary to drain the oil, I just leaned the bike on its slider but I thought,I'll change the oil now, so I drained the oil and the coolant. The water pump has a stick ??? That needs to be aligned with a little tip inside the crankcase, so when you pull the water pump try not to move the stick I'm talking abuot, I did it and it was a PITA to align it again... No more oil leaking =D |
