Numbness in fingers after long ride
Had it as well. Dr. stated CTS (carpel Tunnel) Had surgery on the right hand......Never needed it for the left. The Left Hand saw what Happened to the Right and it scared him straight! Its easy to rest on the palms of your hands while on long rides. Elbows out and focus on leg cues. Your inner thighs and Knees can help. Try turning your bike with your pegs and feet! You will be amazed at how much response you get. Use all these in tandem to give the hands a rest.
I appreciate all the pointers, I do think I may have carpel tunnel setting in though to so I guess riding doesn't help. I don't think ill stop riding though, sucks getting carpel tunnel at 29 figured I'd be at least 35 before I experienced fatigued body injuries lol. Hopefully, new grips and different riding tech. will help out enough.
Classic said it: check your riding position.
I did a lil experiment a ways back in a safe area. Got on the gas a bit and braked hard. While braking, I paid attention to how much weight / pressure I was putting on the bars. Turns out it was a ton.
That showed me I was supporting myself with my arms and not with my core muscles. It'll lead to arm fatigue, numbness and mess with your ability to control the bike. Only thing I could do to correct it was force myself off my arms. A lot of hard braking practice, with the goal of not getting shifted forward and using my core to keep my position. If I could do it during braking, I would do it naturally during riding was my theory.
A lot better at it now but need some tank grips cause the nut taps sucked
Yep,
Squeeze the tank a little more with your thighs so you can hold yourself more upright. A good test of this is to be able to flare your arms/elbows in n' out. If you are on your wrist too much you obviously couldn't flare your arms back n' forth because of all the weight on your wrists.
Also, something not entirely related but adds to the mix, is the constant vibration in the handle bars. I forgot where mine are from but I have solid aluminum bar ends/weights that dampened the vibration tremendously. Actually, just found them.
Hudson Valley Motorsports Parts - Motorcycle Handle Bar Ends for Honda motor bikes to Reduce Vibrations
These things are CLUTCH...
