No start. Has fuel. Injectors fire. Plugs fire.
Old Jun 22, 2022 | 03:12 PM
Treeman83's Avatar
Default No start. Has fuel. Injectors fire. Plugs fire.
02 954. Guy stated it cut off while he was riding and he Parked it. No codes. Plugs have spark. Injectors puff a spray of fuel. Brand new battery. Fuel tank was empty, I put a gallon in it. Still smell bad fuel after cranking. It will not fire on starting fluid either. I ordered coils and stator rectifier before I started digging into it. As well as the Haynes manual. Is there anything someone can think of I can try while I wait on the manual? Pump primes fine. I'm at a loss. Went through every connector and ground on bike. Fuses are good also.
Old Jun 27, 2022 | 02:31 PM
backdoc's Avatar
Has the ignition pulse generator been removed from the clutch cover? Sounds like the timing is off. Use a paperclip or piece of wire and short the service connector under the seat and see if there is any trouble codes in the computer.
Old Jun 27, 2022 | 08:30 PM
Treeman83's Avatar
No codes. Just the 9 when I unplug the iat. Coils stator and rectifier just replaced. I was crossing my fingers, but still nothing. Manual will be here before the weekend. I will hopefully figure it out then.
Old Jun 27, 2022 | 08:31 PM
Treeman83's Avatar
I will have to take a closer look at pulse generator.
NineFiftyFour
May 6, 2013 12:43 AM
BTBTBT
Aug 30, 2010 03:00 AM
onefastRR
Mar 31, 2010 12:32 AM
nrecore0223
Mar 6, 2008 06:01 PM
stuntn_r6
Sep 28, 2007 08:03 PM
