No spark= Unhappy
#331
#332
#333
Like your ingenuity setup though I'm not sure how your "supposed" to assemble this bikes from the ground up. Keep up the good work and the pictures!
Like the
#334
I was going to say the same thing about the screwdriver, unfortunately it becomes a two man job with paint or pc on the tubes. Buddy of mine was looking to PC his tubes but changed his mind just because of that reason.
Like the
Like the
Thanks guys
Here are some updated pictures
IT'S ON THE GROUND. For the first time in a year.
Just a few more things to do before start up. Exhaust, coolant pipes, throttle bodies, air box, and fuel tank. Wish me luck.
#336
So I went to start the bike a couple nights ago and it cranked a few times and then the starter solenoid just started clicking. The battery is shot and I also believe the solenoid is fried also. So next Friday I will be ordering a new battery and solenoid and hopefully she will fire. I am also getting a r/r-stator wire repair kit since the connector is missing and they are hacked together. I guess this will give me time to do some other things that I need to get done. The calipers need put on and the brakes need bleed. The coolant system needs flushed and bleed. The under tail needs to be painted since I did a bunch of body work to it to smooth it out. I also have a few misc things that need to be done. When I receive the new parts they can go on and this thing will hopefully be done and on the road.
#337
#339
#340
You guys are most likely right about the solenoid. I think a new battery will probably solve my problem. The motor sounded like it was about to fire though before it all went dead. The gauge still lights up and the horn, blinkers, and headlight all work but it just wont crank over no more. I might see if my buddy will let me borrow his battery from his 600RR to see if it fires.
