No Blink
Hey guys my turn signals dont blink cant find a flasher relay or anything manual says it all goes into the istrument panel. I recently changed signal and the guy at the shop said it might be a matter of adding a resistor or something. The problem happened before I changed the lights though, also the light that came with the bike was cracked maybe water got into it .Any suggestions?
RE: No Blink
CHECK UR FUSES, IF NO PROBLEM THEN IT MIGHT BE YOUR TURN SIGNAL SWITCH, I HAD THAT PROBLEM LAST YEAR, WATER DAMAGE.
RE: No Blink
stock signals... or leds???
RE: No Blink
No LEDs just normal bulbs
RE: No Blink
always check fuses first. if they are ok then its most likely water damage. i never had the problem personally but i have a friend that had the same problem with his yamaha
RE: No Blink
After the fuse I would go after the switch it self I ahd the same prob on my wing and water had gotten in and just was not making good contact.
| All times are GMT -5. The time now is 07:07 AM. |
