Need new fuel pump, are the KEMSO or Keshen pumps a direct fit?
My fuel pump went out on my 954rr and I need to purchase a new one. All the used oem ones are considerably more expensive than new aftermarket ones. I was wondering if anyone has installed a KEMSO high performance aftermarket fuel pump and would like to know if it is a direct fit. Same question also for the Keshen Fuel pumps. If not could someone direct me to one that will? Here are links to the 2 pumps I am referring to, any help would be greatly appreciated!!!
Fuel Pump Replace for Honda CBR954RR Fromm 2000 to 2003 | eBay New Intank Fuel Pump for 2000 2003 Honda CBR954RR | eBay |
I would assume the used OEMs come with everything, the filter, the mount, etc. Have you looked at bikebandit or RonAyers for a Honda pump? I'm sure the eBay pumps would still be cheaper though.
I once considered a KEMSO pump but opted against based on a review I read on another forum. If I dig it up I'll send it to you.
Check a parts Microfiche. Very likely it will be same part # from 929. |
Are you sure the fuel pump is bad? Maybe it just needs new connections where the wires connect to it. I've seen somewhere where that is very possible.
Originally Posted by coalminer frank
(Post 1298930)
So ill be driving on my bike and all of a sudden it will die on me. Ill try putting it in gear and letting out the clutch to start it again and nothing. I pull to the side of the road and when I turn the key I don't here the fuel pump prime at all. The shop thought it was just a bad connection and put 35 miles on it without and issue. Lo and behold after picking it up from the dealer and riding it back it died out on me once again. My gf who was following me at the time stated that my lights flickered before the fuel pump cut off on me. Any help is greatly appreciated. It is currently at the dealer waiting for a fuel pump. |
Originally Posted by Boosted9
(Post 1299293)
I'm pretty sure its the fuel pump. The bike only has 8k miles on it and there were some summers where I didn't ride it much so it doesn't surprise me if the pump and filter got all gumped up.
