Need Help & Need a Favor
Need help finally goot to take out the bike today first real ride on 954. Heres the questionwhat tempeture does your bikes run. I hit 203 degrees today is this normal. What temp. does the fan kick on.
Heres the favor i tried to download the service manual off of here not working for me. If someone already has it downloaded could they please send it to me in and E-mail oscar16301@yahoo.com Thanks, Clint |
RE: Need Help & Need a Favor
I'll be e-mailing it after this post. 203 is about normal depending on the outside temp and the speed you are running. My fan kicks on at 212, I routinely see high 190's and low 200's when I am traveling through a housing area or an doind less than 25, at a stop light, stop sign, etc... I think you are opperating at a pretty normal temp, but I don't know the circumstances when you got the reading. I typically run 165-185 on a 85 degree day, but when I stop she'll climb up to 212 and then the fan kicks on and It'll drop again as I get cruising.
Hope this helps, I'll get you an E-Mail with the manual. wildcard |
thanks alot your reply was exactly what i needed.
Well I tried to E-Mail the 954 Manual to you, but this was what I got in response,
"Windows Live Hotmail did not receive the entire file you uploaded. This is usually due to a temporary Internet connectivity issue. Please try your file upload again." ------------------------------------------------------------------------------------------ If anyone else can get the manual to him please do, we might need to repost the previous sticky with the manual in it. Good luck. wildcard |
click for manual http://www.stephygee.com/954RRmanual.zip
i know you've posted this before cuz it was for me lol |
I've tried that link it doesn't work for me.
I dont know rum, i tried it again just now and works fine.
If you cant get it to work ill try to compress it since i have it and try to send it to you or whoever needs it.
Mine runs around there. I know where im at it was about 90 and sitting at a stop light for a few minutes it got to around 215 maybe a few higher. Drops fairly quick as soon as i start to go though. Is this normal to be at 215 or a little higher ata traffic light with a hot outside temp?
| All times are GMT -5. The time now is 07:27 AM. |
