Need Help!!!
#21
#22
#24
#25
RE: Need Help!!!
Yes some fluid will return to the cylinder. Once you compress the piston that fluid has to return back to the cylinder.Once you pop the new brakes in check it and fill as needed. Me personally I use my rear brake never..... I put like 20,000 miles on my bike and have replaced the rear pads once.
#27
RE: Need Help!!!
this should be the process, remove cylinder cap, compress piston, pop in new pads, put cylinder cap back on, pump brakes, if needed add fluid or bleed brakes. If you can stop and your satisfied with the way your brakes feeland are safe at the same time then dont bleed them. If you didnt have problems with the brakes working before pad replacement then you shouldnt have to bleed them, well unless you took the brake line off the caliber and leaked fluid all over the place.
#29
