MORE SPEED!! what should i do?
Old 06-18-2008, 12:17 AM
Hcstreetriding's Avatar
Default RE: MORE SPEED!! what should i do?
ORIGINAL: TK954RR
Now granted i dont know bikes as well as cars so i have to ask, cant the stock ecm be flashed, or retuned? I assume dealers can do it, so couldent someone else buy the needed equipment, then you wouldnt need the pc3.
Yes, its possible, if they will do it or not i dont know. I would doubt it since a Pc3 is so cheap and basically easier and better.
Old 06-18-2008, 06:57 AM
txsmainevent's Avatar
Just get a turbo
Old 06-18-2008, 09:18 PM
NastyNINA54's Avatar
my mechanic went into the ecu and changed the amount of gas flow or sumthing,he said itdoes the same thing as a pc3 without paying $300 or so. maybe not as detailed or sumthing. i dont know. i do have a full hindle exhaust and i thought about getting a motor built but really cant throw that much cash into it rite now. tryin to save 4 a good ole vacation to jamaica. turbo does add a lot of power, but from what i heard its easy to blow a bike motor up with one. dont know if i want to take that chance.
Old 06-18-2008, 09:19 PM
nikos's Avatar
ORIGINAL: TK954RR
Some can, some can't (depends on the micro and how accessible it is). I'm not sure on the specifics of the 954 (or Hondas in general), but I don't think they would give that kind of flexibility to the dealers to do a custom tune. If you could reflash, the dealer would probably only be able to use a specific program rather than a truley custom tune.
I've never heard of a program to help you tune the ECM, so I wouldn't even know where you'd start...
Old 06-18-2008, 09:23 PM
nikos's Avatar
ORIGINAL: NastyNINA54
There's the answer on the ECM... Sounds like you just need the right software/cables.
As far as a turbo, we already have a pretty high compression ratio. I would think you'd need to run race gas and/or run it at very little boost to have the motor last more than 5k miles...
Old 06-18-2008, 09:35 PM
Heres the deal with the PC3 vs. tuning the ECM.
Would you rather use a hammer to drive a nail through some wood or your forehead?
Bottom line, pick up a PC3 for a buck fifty and a custom tune for maybe $300, or blah blah with the ECM and get half as good a tune if your lucky and risk frying a $125 part for some ****ty performance gains.
up to you.
Old 06-18-2008, 09:36 PM
PlayfulGod's Avatar
ORIGINAL: Hcstreetriding
up to you.
hahah... TRUTH!!!!
Old 06-18-2008, 10:02 PM
i must've missed sumthing. since when was a pc3 only $150? every place i check is around $300 just for the pc3. if its only 150 i'll go ahead and get it.
Old 06-18-2008, 10:40 PM
look on ebay, i see them between 100-200 all the time
Old 06-19-2008, 02:30 PM
oh ok. new or used? a guy i rode with one time said he ordered one from a website and they sent him a used one, and had to go through a bunch of **** to get his money back. if they're new i'm gonna have to try one out
Quick Reply: MORE SPEED!! what should i do?
