-   CBR 954RR (https://cbrforum.com/forum/cbr-954rr-21/)
-   -   map sensor check engine light. (https://cbrforum.com/forum/cbr-954rr-21/map-sensor-check-engine-light-112637/)
svt954 Jun 21, 2010 11:04 PM
My 2002 954 check engine light is on. I checked the code and cross referenced the service manual. The code is for the map sensor. Will replacing the map sensor w/ a brand new one fix the problem? Has anyone ever had similar problems?
letsride Jun 22, 2010 05:10 PM
Should fix it but I would also check for any loose wires that may have caused the light to come on.Never has happened to me though.
Chamoru671 Jun 22, 2010 05:55 PM
My check engine light when on for the map sensor, found out it was only loose wires.
Omaha rider Aug 6, 2011 11:23 PM
How can you tell the code if the light is on solid?
