Lowering again
Old Jan 17, 2009 | 08:59 AM
Getz2003's Avatar
Default Lowering again
I lowered the rear on my 54 2 inches. Should I or do I have to lower the forks also? If so, any suggestions on using the brackets opposed to the straps?
Old Jan 17, 2009 | 10:52 AM
Outlaw 954's Avatar
Default RE: Lowering again
yes if you lowered the rear lower the front also or it will look totally uneven and for the front just lower using your tripple trees when you use the strap it takes the rebound and the preloading out of you forks.it will be more like a stiff strut if you tie your forks down.
Old Jan 17, 2009 | 01:42 PM
Honda4Ever's Avatar
Lowering only the rear will also make the bike want to push in the corners. Of this I am certain. When I bought my bike a female had owned it and she had short legs so she installed a a lowering link dropping the rear 2". When I purchased it I let it alone because I kinda liked the way it sat, but the first time I hit my favorite twisty road I almost low-sided her several times. It makes the bike dangerous if you have an agressive riding style because it causes the bike to carry more weight in the rear litening the front somewhat. I could even see it in the way the tires wear. I had almost no chicken strips in the rear and about 1.25" chicken strip in the front. After I raised the rear back up it handles alot better and the strips evened out. Thats my experience, yours may vary but I doubt it.
subyman1440
May 7, 2012 06:26 AM
Hustlin Hussy F4I
May 4, 2012 10:39 AM
jtboyd91
Jul 23, 2010 08:24 PM
showerslll@yahoo.com
Jan 19, 2009 07:33 PM
BADassCBR
Jan 19, 2007 06:41 AM
