lets see thoes blinkers
RE: lets see thoes blinkers
L&C. Here is a fresh pic of my protons up front. Very clean, bright, also serves as a running light.
Here is my girls rear end! Hot tails kit with lights. They are LED's as well. I have also added High Tech Speeds UFO light kit to the rear brake light. They are sick! It has programmable brake, turn, and running light modes. I wish I would have just put an undertail kit with no turn signals now..........
i kinda like these for the front
http://estore.websitepros.com/873942...LED/Detail.bok
and rear
http://estore.websitepros.com/873942...-03/Detail.bok
and rear
There is no doubt as to what direction you are going"AND" applying the brake. The replacement LED board is much brighter than the stock one on the 954. I dont know why? They are both LED though. If I would have known that. This would have been one of the first mods I performed on the bike. The really great feature is on the running light. Cagers know your there just when cruising. Its a great product. Expensive, but worth it!
You swap out the factory board for the one from High Tech Speed inside the rear light. Its a test of patience.........You very carefully seperate the rear light housing. Replace the board, splice wires and then seal it all back up. It took me 3 days to patiently get this one done. Great project to do while the roads are covered in snow.
check this stuff out
http://www.devilbikes.com/bodywork_p...EmQ0JSIDk1NA==
http://www.hotbodiesracing.com/signals.htm
http://www.hotbodiesracing.com/954RR_ut_sbk.php4
ORIGINAL: CBR_954_RR
Hey, just so you know...those turn signals in the corner of the headlights (brow lights/euro signals) can be done for under $10 with parts from your local auto store. I did mine about a month ago, and they look and work great!
