How to cancel my bike speed limitation (180kph)-need a prof. help
Old 09-06-2007, 07:57 PM
demonchild's Avatar
Default RE: How to cancel my bike speed limitation (180kph)-need a prof. help
Just out of curiosity, what happens in Japan if you are caught over the speed limit. For them to tell manufacturers what to set the governors at seems like they really dont like people traveling at more than 180km/h.
Old 09-06-2007, 08:24 PM
ORIGINAL: nikos
How to change it depends on how they take the measurement in the system. For whatever reason, Hayabusa was rumored to only have the speed governor kick in when the bike was in 6th gear, so the kit tricked the bike into thinking you're in 5th. Try driving in 5th and see if it redlines or governs out.
Otherwise, disconnecting the speed sensor should work if the governor reads the speedometer CAN or J1850 messages. If it reads it off of gear indication and the RPM sensor, then disconnect that sensor and see what happens. There's a lot of different ways of doing it and I'm not sure what Honda did... You could always try swapping the ECMs, but ya never really know what else is different between the US and Japan versions.
Hope this helps!
there is only one output speed sensor-it does not care what gear you are in!!-the most simple
way to overcome this problem-is to swap engine modules-if not there might be more than one
problem to solve! before said and done!!!
Old 09-07-2007, 01:00 AM
CBRinPDX's Avatar
I heard that in Japan the police are only allowed to reach a certain speed. All you have to do is overcome that point and they won't even bother... Is this true?
hmm.... MaybeI got this from'Tokyo Drift'?....
Old 09-07-2007, 08:47 AM
VP's Avatar
VP
VP is offline
ORIGINAL: CBRinPDX
HAHAHA yep I thought the exact same thing when I read this
Old 09-07-2007, 12:20 PM
motoxxx43's Avatar
Hey karimreda, you have a Jap spec bike, where did you get it and where are you riding it? My buddy is in the Navy and wanted to pick up a bike real cheap overseas but to ship it back would be so expensive it would not be worth it. . . What colors are your bike?
Old 09-07-2007, 12:21 PM
motoxxx43's Avatar
Old 09-11-2007, 03:40 AM
karimreda's Avatar
First thank you all for the try ... but i would like to note that i live in EGYPT and not in JAPAN
I was thinking of the speedohealer option and converting it to miles in stead of kmp and therefore the ecu will read 180 from the gauge as jsut a number. Any one tried this before??
Old 09-12-2007, 03:01 PM
karim bhai try swapping the ecu or buy the de restrictor
Old 09-15-2007, 10:48 PM
i think by just changing the ECU will solve the problem
Old 09-15-2007, 10:59 PM
PlayfulGod's Avatar
It was in Tokyo Drift, Hon said that the police cars could only go 180kpm so if anything went faster than that they didnt even bother with em lol.
And yea I say try changing the ECU out with a US version.
Quick Reply: How to cancel my bike speed limitation (180kph)-need a prof. help
